Kuma
Installed Ironridge tile hooks and installed the first set of rails today. I used a good 6 ft level for the top and bottom 22ft rail sections. The rails dont look quite level with each other though, not parallel. Maybe ~1 inch off in 22 ft? I would imagine if the rails are not parallel the panels would be twisted somewhat, not perfectly flat when installed. I read the Ironridge install instructions and all it says is to level rails.
Some say they run a string from each end of the rail section to try to make the rails flat, not follow roof contours and have high points. I did not do this but should probably check the rails with a string.
I am curious what others do and am open to suggestions.
btw - the house was owner built in the 70's and few things are straight, plumb, on center...
