Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,701
Some years ago my upright freezer stopped keeping things cold enough Recently measured about 32 degrees F, and it varies with ambient. We started calling it the "Deep Fridge".
It takes the same R134A as my car, 6 oz., so I decided to try refilling it.
I have a refrigeration manifold and pump from Harbor Freight, so didn't buy a kit with hoses. I just bought the following piercing valve:
This one is "Chinco" brand. I've read reviews mentioning lesser makes with metal debris that didn't seal, and another might be the name brand.
Lately 12 oz. cans of R134A have been $20 + $10 deposit and Winchester Auto and Auto Zone. At O'Reilly it was $7 + $10 deposit (I guess they didn't get the memo.)
I have a small scale for selling recreational ... (um, never mind), which I put to use measuring weight of refrigerant can:
Based on later readings, I think my attempt to weight the can with hose attached had error.
I tried to evacuate the hose, but without a good valve at the can was unsuccessful so pressure purged it.
Anyway, after putting in a couple ounces, I monitored the freezer. It got down to 15 degrees F.
I tried more later, intending to get close to 6 oz. Don't know how low it had been.
I also tried measuring temperature of discharge and suction lines. Readily available suction line was too close to compressor, so above room temperature. So much for making this a science.
What remained in the can I put in my car, which I had only charged with a single can before. Careful weight indicated car got 8.3 oz.
Final weighting of empty can (3.42 oz.) showed contents had been 12.21 oz, so refrigerator got 3.91 oz (less whatever was lost purging hoses.)
Freezer now runs about 5 degrees F, saw 0 degrees once.
Seems like thermostat at warmest setting doesn't cycle off even at 5 degrees F, need to determine what range it is supposed to have. Possibly replace; that would let freezer run a bit warmer and not operate compressor constantly.
2 Pack BPV-31 Bullet Piercing Tap Valve Kits Compatible With 1/4" 5/16" 3/8" | eBay
Find many great new & used options and get the best deals for 2 Pack BPV-31 Bullet Piercing Tap Valve Kits Compatible With 1/4" 5/16" 3/8" at the best online prices at eBay! Free shipping for many products!
www.ebay.com
