All depends on the application and connection you’re making.BTW, anyone got any tips for info on best practice when to use ferrules, just a twisted cable, when to solder end terminals and so forth?
Currently I am looking at a 50 foot run. I can understand the possible trade offs.If it's a long run you likely get lower resistance using the bigger wire and the ferrule
Hoo boy, that's a can of worms you're opening up there. In general, we tend to crimp and not use any soldering. In a mobile environment the solder can become an issue. I use no solder in my RV and I'm happy with that because I suck at soldering.
If a terminal involves compressing the stranded wire then I like to use a ferrule. I have used a lot of ferrules in my install. I think my terminals stay tight better when using a ferrule.
If it's a set screw terminal, I use a ferrule.
If it's a clamping terminal, I don't.
And why don't you use a ferrule with a clamping terminal? I assume you mean by clamping terminal is what Victron Energy uses on many of their products.If it's a set screw terminal, I use a ferrule.
I'm not sure what Victron uses. But I posted a picture of the clamping terminal above.And why don't you use a ferrule with a clamping terminal? I assume you mean by clamping terminal is what Victron Energy uses on many of their products.
I can't envision a ferrule that reduces the circumference of the wire.I was out on the Midnite forum. A user showed how they used a reducing ferrule to feed larger wire into the charge controller. Anyone else with this experience?
I don't think they mean ferrule. Ferrules and pin terminals are often discussed together.I can't envision a ferrule that reduces the circumference of the wire.
A pin terminal would though.
Pin Terminals | Vinyl & Nylon Pin Terminals | Ferrules Direct
Our pin terminals offer a quick and easy connection in applications where set screws or clamps are used to make electrical contact with the wire.www.ferrulesdirect.com
What is the load that sinks 800A?lol
I'm going to be using parallel 500 kcmil, to tie two battery banks together. Because I need to carry over 800 amps.
That's an amazingly large inverter. I just read your profile.30kw of inverter.
48v battery bank.
