Looking for recommendations on a BMS for this high amperage configuration.
I am about to pull the trigger on (2) Headway Superbeast 24v packs from Battery Hookup for a 48v Golf Cart.
Each pack is 24v 8s6p and I'll need to wire them up for 48v to the controller.
These packs are built for high discharge applications and include a contactor on the outputs, pre-wired for BMS and include a large fuse. I'm going to start with 2 and possibly expand to 4 for more run time based on how it performs.
The golf cart has already been upgraded to a Navitas 600a controller, and also has a large solenoid installed for use with the current LCA 48v batteries.
Given that the cart has a solenoid and each pack has a contactor, I'm trying to find a BMS that will play well in this setup, rather than starting over.
Any ideas are appreciated.
SUPER BEAST 24v 48ah 1.23kWh Lifepo4 - 48 HEADWAY CELLS
You get 48 Headway cells plus you get all the 300a busbars, wiring, and cells holders. This is by far the best deal on Headway cells. Now lighter and a little cheaper to ship as well. The modules are confirmed to be balanced and fully functional. This is a pure power module. Connect this one...
batteryhookup.com
