I must say, pretty impressive. What do you guys think?
Bummer they can only go in series ! Hopefully that is just temporary and they'll figure out how to make 24/48+ V
oops, fixed, was a bit distracted.... was working on #1I know you just mis-typed, but I'd hate to see someone make a couple thousand dollar mistake. They can only go in Parallel.
In the YouTube comments I found this:Why do you suppose they cant be connected in series?
The reason there is 4 wires is to carry the load, they can't put say 1/0 cable in there and attach that to the BMS, so instead they us "pairs" that allow for the capacity without the single larger wire in there. This is not unusual or strange, it is a common way to ensure the wire capacity is there to handle the amperage going through it.
The internal BMS is designed for 12 Volts not 24,36/48 , setting batteries in series take the voltage up and will fry the BMS because it's over voltage. This is largely due to how the boards handle the voltage, cut offs etc. Some BMS' can handle various voltages allowing for Series & Parallel but these are more costly and complicated typically with external handling of the throughput power. BMS' which use FETS are limited by FETS and typically not seen on a BMS rated higher than 150A and are limited to specific voltage ranges, above 150A the BMS' will use either electronic or electro-mech Relays due to the power running through them and are usually capable of different voltages as a result.
This is quite a generalised & basic overview, hope It helps.
Seconded! I am getting suspect info from Renogy support. I received a screen shot that shows I should set my Float voltage to 14.4, same as Absorb(boost) and rebulk at 13.2v
I have been under the impression that LiFePo4 batteries should not use the Float setting. So that has me concerned.
@ScottyH, just keep asking and documenting it with the case numbers so if their lack of support causes a premature failure of the batteries you have the documentation to back your claim. The only spec in that manual is charge voltage 14.4 +-.02% Nothing about about absorb, float or rebulk. Maybe you can ask them for the screen shot of the manual page specifying those battery settings.. I will keep trying to get them to respond with actual answers. -Bill
This is true only when all batteries in series are in the ON state. But the moment any one battery BMS goes to OFF state ( any protection event like cell voltage or temperature ) that BMS will "see" combined voltage of the whole pack. @Steve_S is correct that it's all about voltage rating of the FETs. Lower voltage FETs are cheaper and have less resistance, which is more desirable for BMS design. So, its a trade off by design and Renogy decided to focus on 12V applications only with this particular battery. They can still sell a boatload of them even without series connections.I must be missing something about the voltage. Voltage is the potential between two point so the battery only ever 'sees' the voltage between it's two posts. It does not see the voltage of the whole string. How is putting them in series creating higher voltage on one of them?
i know they are 26650's 4s30p but i would love to see a teardown on oneDoes anyone know what the old renogy battery looks like inside?
