Hi all,
Ok, i decided i'm going to replace my batteries bms's because the Narada's bms settings is not accessible and the controll is not good. I have times where 1 or 2 cells volts have reached 3.75v before the bms stops charging. Now, comes the big question, the Seplos looks like a streight swop regarding the existing holes for comms, dip switches and led's, plus i get a display and bt with it.
IF another bms is suggested, i'm not too worried about the holes, i can close them.
Sooo, for adjustability and controll of settings and max info on monitoring the cells, which bms would you suggest?
My batteries is Narada lifepo4 48v 100Ah 15s. At this stage the comms is not connected to my inverters as they can not communicate to narada's. I have 2 Axpert 5kw hybrid inverters connected in parrallel.
