resisters as the heater
Mojobus
Hi,
Does this also work if I connect the resistor directly to the 12V battery ?
Well sure, technically a heating element is just that, a resistor...
But that would mean 6 x 25w =150W heating power, which is too high. Probably the load resistors would not withstand this in continuous operation. How can I simply limit the current?
I need maybe 20-30Watt heating power
but I would like to have it on an area of 40cm x 40cm distributed from below on alu
How did you come up with that calculation?
What is the resistance of those resistors? If you want to dissipate 30W of power @12V then the load resistance will be 4.8 Ohms.
resistors 10 Ohm
Six 10 Ohms resistors in series = 10 Ohms * 6 = 60 Ohms.
Using Ohms law: E = I *R
Current (I) through the 60 Ohms of resistance (R) = E/ R = 12V/60 Ohms = 0.20A
Power dissipation = I * E = 0.20A * 12V = 2.40W
You can connect just three 10 Ohms resistors in parallel, the total resistance will be 3.33 Ohms.
So the power dissipation will be about 43W.
Series, parallel resistor calculator:
Do the three parallel, then double it and parallel the other three, series the two groups together and you have 6.6 Ohms for almost 22W.
I think @Mojobus is saying he wants to put the heating resistors under Aluminum. If that is correct, why not use a cheap heating pad? I'm using two 12V / 12W heating pads under my 8 cells, and it looks like it is working really well. Nice and flat, which high power resistors are not.
935B11B1-1D94-4906-9A2C-EBCB9D3EE7C8.jpegI am using 25 watt silicone heat pads sandwiched between thin aluminum sheet and they are keeping my battery boxes in my truck at 50 degrees with temperatures in the 30s. But I am heating the air around the batteries not directly on the cells.
I used 4 of these 7W polyimide heaters. https://www.amazon.com/gp/product/B07P2RJDPL. I attached them to a .060” aluminum plate I had and covered them with felt and Kapton tape. I covered the other side of the plate with phenolic tape to give the cells something to slide on as they expand and contract in my compression fixture. At only 28 Watts, they heat my cells gently and evenly. Of course, the whole thing is in an insulated box.
I did some testing with those same heating pads. They were actually the first ones I tried. In my tests, they got way too hot way too fast. Although they are only 7W, the max temperature they are spec'd at is 100°C, which is 212°F. That is really hot. I think the silicone heating pads (larger area, and usually limited to 60°C) are better for this application.
The heaters themselves might very well get that hot if not attached to anything as they have almost no thermal mass and little surface area to dissipate heat. After I attached them to the aluminum plate, I could not get the PLATE hotter than 110 degrees. That was in air with no mass attached. Sitting under the battery transfering heat to the cells, the plate never gets anywhere near that hot.
The heaters themselves might very well get that hot if not attached to anything as they have almost no thermal mass and little surface area to dissipate heat. After I attached them to the aluminum plate, I could not get the PLATE hotter than 110 degrees. That was in air with no mass attached. Sitting under the battery, the plate never gets anywhere near that hot.
Ok, to each his own. My testing was not in air. The heaters were Kapton taped to an aluminum plate with jars on water on top. Still got too hot too fast for my taste. In my opinion (only an opinion) setting your pain threshold at 110°F is too high. I don't think the plate should get above 85°F.
See my other posts graphing the heating of my 8S 230Ah battery. I used two 12V 12W silicone heating pads, roughly 100mm x 120mm. I've found that to move my cells from 50°F to 60°F in my insulated battery box (almost independent of outside temperature) takes 3 hours, and the aluminum plate never gets about about 75°F. I've logged and plotted it all and posted it here.
I put pairs in series for 1/4 the wattage. May not have a fast recovery from a cold soak but that is not my primary issue. Simple slow extended heat is fine. Not going into extreme conditions.
Just to put a bow on my cell heating system performance for those reading this thread in the future, the aluminum plate in my cell heater system transfers heat REALLY WELL into the cells. It's hard to measure with everything assembled, but I do not believe my aluminum plate gets even 10 degrees F above cell temp. So at my target heater shut-off temperature of 44 degrees F, the plate would be below 54 degrees F.
BOTTOM LINE: I've been pleased with the system performance this winter and would do it the same way again.
