wmills_92105
- Nov 24, 2020
- 124
This is my set up for top balancing my battery pack. It is a Riden 6006 power supply Being driven by the battery charger that I will use for the whole system that is putting out 14.4 volts. The Riden is set to 3.65V and max 6 amps.
The cells are 8x Fortune 60Ah cells starting at 3.3V. Using 16ga for this since the amps are limited by the Riden. The Progressive Dynamics charger is also fused.
