I have been gathering the components for my solar build and the one thing I am not sure about is how to get the wires from the inverter/charger to the distribution panel. The installation is going in a R-Pod 180 where the distribution panel is in the under the dinette seat as you enter the RV. So the AC is routed through the interior floor to the opposite side (Driver side of the camper) and the DC comes from the batteries on the tongue from underneath.
My plan is to move the placement of the battery (new LiFePo) to inside the front storage which is under the bed. I also plan to have the smart shunt, MPPT and Inverter/Charger there as well to keep the battery cables as short as possible from battery to inverter.
So my question is, do I kept the same route of the DC to the distribution panel and drill a hole in the floor or run the wires inside. The distance is about 7' in difference between inside and outside and I haven't determined if I can fit a 6/3 through the access route in the floor for the the inverter to distribution panel.
Also, can I use 6/3 SOOW or SEOOW instead of marine triplex since it is about half the cost. I know it is for portable power. I guess another option would be to use THHN if I stay inside.
TIA
PS Link for floorplan
TIA
