Gotbeans, while the power is working though, how does the water know to go to the booster pump and not the bypass? Wouldn't the water flow to both the bypass and the booster then and if so, is that bad? or doesn't matter?
the water doesn't know anything, it flows the path of the least resistance
when the booster pump is on, the check valve will close (as I said like 4 times already lol)
the pressure from the pump will close the valve, there's no way it'll open while the pump is on, you'd need a tank to push that thing against the pump
If the water flowed through both, it wouldn't be bad, but it isn't possible. If the pump was on and there was no valve it'd go in a circle and that
would be bad which is why we have a check valve.
Ok, thanks you two. I think I have it pretty much figured out.
I will bring with me a low resistance check valve.
First I will replace my current one and unplug the booster pump, so it doesn't have electricity. That way I will see if water will run through without power.
If this doesn't do the trick, I will put the pressure valve back on and create a bypass with the "T's" and put the low resistance check valve on the bypass.
Makes sense to me, am I correct with what to do?
You have to use the one I linked which is expensive but looking at the specs will last longer than we're alive probably
I looked at like 200 check valves all over different stores and saw none that were low enough psi to open. All of them are like 4+ psi I don't think your cistern will open them
all the home depot / lowes ones etc are worse or the same
You don't have to replace the current one, I'd just ignore it entirely. Just put a bypass in
