It works!!!! Just got done with the first cut. Had 58% battery left after 1.25 acres! No bogging down or anything. I can do burnouts in my drive too! The weight of this rig is about the same as just one of my 4 SLA batteries. So pumped. Here are build pictures along with descriptions. It's my first build so if you guys see anything obvious that I should have done differently just let me know.
The biggest thing I would change is the enclosure obviously. I had planned on using a Pelican case and even purchased it but I just couldn't get it to fit right within the frame of the mower. I'm in the process of remodeling my kitchen and had a bunch of scrap maple cabinet grade plywood that was already sealed and finished on both sides. I used pocket screws and glue and then applied some adhesive roofing flashing I had around the edges. The hole is for a long bolt which goes through the existing tray to secure the battery to the chassis.
![IMG_1895.jpg IMG_1895.jpg](https://diysolarforum.com/data/attachments/66/66708-d267417326092d85551dc5bd67722a3c.jpg)
I got the cells from Michael Caro's group buy and used an Overkill 16S BMS. They are 100AH cells. The two larger groups are taped with Kapton. The cable that joins those blocks was used in my original SLA configuration. The reason for the layout is to allow the long bolt to pass through and secure it to the frame. I packed everything tight with foam as it's likely to get rocky in the mower. The bottom is lined with foam as well.
I used the existing quick connect cable and bolted the negative leads together and used shrink.
The box sits in a metal tray that can can be slid out on the existing rails. Here it is in the stripped down mower. Complete removal of the sides isn't necessary. I had some cleanup to do on the mower though.
Two bolts secure the tray in the rear and the one long bolt through the center. Drill twice, measure once..
Fully reassembled and charging.
![IMG_1942.jpg IMG_1942.jpg](https://diysolarforum.com/data/attachments/66/66714-51d61cb11424472a425a78b3b9b2bad4.jpg)
BMS reading after full charge.
BMS reading immediately after full mow (1.25 acres).
Notes:
Because of the voltage and curve differences, the on-board battery level always reads 100%.
The charger had an error on it when charging was completed. It's designed for SLA though and is an intelligent charger. Might just be something I have to live with. Possibly because of the voltage level and impedence? Not sure.
I'm charging to full again and then plan to open up and inspect the pack and see if any errors or anything are thrown on the BMS during the process.
Anything else I should do? Thoughts? Also, thanks everybody for your help!
