Trying to come up with the best way to deploy this Schneider Electric Conext XW MPPT 100-600 charge controller.
It has a capacity of 100 amps and 600 volts.
I ohmed out the PV connectors, they are all common.
So if I have two or three series strings of PV panels, connecting them to the charge controller makes them parallel?
Am I understanding that correctly?
If so, the only way I can get a series PV is by doing one single giant string.
I had originally wanted to use the Panasonic VBHN340SA17.
8S will provide about 550vdc @ 45amps.
Seems like a waste when the CC can use 100A.
So instead of Panasonic, if I ran 10S of these REC solar PV, looks like I would get 440vdc @ 95amps.
Is this more reasonable? I am trying to charge 445Ah of FLA.
