CopperTopper
I am having the exact same issue as others with a XW6848 pro, SCC100-600 and Grid Support Selling. The battery is a fortress e-vault with closed loop comms. This issue has been going on for over a month and I have tried everything and all Schneider does is want to down grade and upgrade the firmware and waste my time. I can not get the solar alone to sell without selling battery power with it. This is with the GSV above 65! I have also had issues with settings not saving when all my devices had the latest firmware. You would literally change a value, save it, wait for it to go from green go back a page or refresh and come back to the page you just adjusted and the original value would be there! This was with InsightLocal and the cloud. Schneiders response was to down grade the current firmware and then install the latest firmware (again, wasting more time to run out the clock) and that fixed the problem for maybe a day. All while trying to get the system to sell power to the grid. I currently have a older firmware version and I am not having issues with settings staying so I am leaving it because the newer versions did not do a damn thing in terms of Grid support and PV selling. I have attached screen shots of this behavior and all my settings that are relevant hoping in desperation someone can help. I have numerous Schneider's in the field that never had issues until this nonsense. Also set Float voltage to grid support voltage and nothing. I have seen and posted this in other threads but it has got ridiculous the time we have put into this
