BentleyJ
Solar Wizard
3 phase doesn't get much attention on the forum but most of the problems with Schneider lately has been with Enhanced Grid Support, Sell Back. Specifically, the batteries getting drained overnight. So far that issue has not been corrected in the firmware but the work-around has been to set Grid Support Volts to the same value as Float Voltage on the Charge Controllers. The effect is to disable Enhanced and revert to simple voltage control which seems to work as expected.
Another recent post described a similar problem, in that case they had Recharge Volts set higher than Grid Support Volts which resulted in a configuration error.
The XW Pro is still a well built, low frequency work horse. The Xanbus communication system is basically plug and play. I recently purchased an InsightHome just as a redundancy in case the ComBox quit working. It was fairly easy to set up using the quick start guide. I did note a few minor incompatibility issues with the older XW+ inverter but those have nothing to do with the XW Pro.
You have to decide what equipment is appropriate for your needs, but I wouldn't rule out Schneider based on what is mostly an isolated issue.
