Sanwizard
Solar Wizard
- Feb 2, 2021
- 2,715
I leave dip 1 on the first battery. For some reason, the software does not like all off. The Solar Assistant software also calls for dip 1 on the first battery.Annoying thing is that I can see the TXD light flash in the software (using COM3) both baud rates and then the ERR light flashes shortly afterwards.
I made a portable connector that works though, using a standard patch cable and usb adapter.
Make sure pin 1 goes to B, and pin 2 goes to A.
The little RJ45 breakout module makes it much simpler than trying to make your own cables. Everything is from Amazon.
