D ddonq1412 New Member Joined Jul 19, 2022 Messages 133 Jan 7, 2024 #1 In the UK were are getting close to zero in some garages. My BMS is restricting to 10amps is there a cold setting to turn off to allow it to charge faster. As exporting 1.5kw back to grid battery at 71%
4 400bird Solar Wizard Joined May 23, 2020 Messages 4,293 Location California Jan 7, 2024 #2 Warming your battery is the better solution. The cell spec sheet for most Lifepo4 cells say to not charge below 0c and it is wise to limit charging as you reach freezing. If you want to bypass the safety feature of your BMS you could remove the temp sensors and warm them up separately from the cells.
D ddonq1412 New Member Joined Jul 19, 2022 Messages 133 Jan 7, 2024 #3 The BMS is reporting it about 8c if the charge would increase it would heat them up and the BMS and cells are in the same case.
houseofancients Solar Wizard Joined Nov 29, 2019 Messages 4,645 Location EU Jan 7, 2024 #4 ddonq1412 said: The BMS is reporting it about 8c if the charge would increase it would heat them up and the BMS and cells are in the same case. Click to expand... If it is report 8c, it is not limiting your charging due to temprature
D ddonq1412 New Member Joined Jul 19, 2022 Messages 133 Jan 7, 2024 #5 What others settings limits the charge on these BMS.
houseofancients Solar Wizard Joined Nov 29, 2019 Messages 4,645 Location EU Jan 7, 2024 #6 ddonq1412 said: What others settings limits the charge on these BMS. Click to expand... Cell voltage , pack voltage, other warnings for the v2 Do you have a V2 or V3 ?
D ddonq1412 New Member Joined Jul 19, 2022 Messages 133 Jan 7, 2024 #7 No warning on the BMS registered. Cel voltage is all over 3.3v V2 BMS. 10e
houseofancients Solar Wizard Joined Nov 29, 2019 Messages 4,645 Location EU Jan 7, 2024 #8 ddonq1412 said: No warning on the BMS registered. Cel voltage is all over 3.3v V2 BMS. 10e Click to expand... What do the management software / app say in the warnings ?
houseofancients Solar Wizard Joined Nov 29, 2019 Messages 4,645 Location EU Jan 7, 2024 #9 Otherwise, you might want to check what the temp sensor on your inverter is registering/ has setup for temperatures
