Sun_Dried_Toad
- Sep 6, 2020
- 83
We are planning for our system upgrade.
Sol-Ark 12k has dual MPPT inputs. it can handle 6500w per input. if done in series only, it can go up to 500v input, but that would be without temperature correction, I assume.
12 panels X 41 VOC = 492v
if panels get cold (it gets FREEZING here during winter) that would go over the 500V input, again, assuming that the 500v input they list is non-temp-corrected. That tells me I need to run them parallel string of 6 series, to another 6 panels in series.
when adding up the Amps for the parallel calculation, do I use ISC (short circuit current) or do I use Max Power Current (IMPP)?
ISC = 10.92A
IMPP = 10.34A
Since I will (probably) be using Mission Solar 345w panels, here is my concern:
sol-ark input max:
500v @ 18Amp (non temp corrected, I think)
or
450v @ 20Amp (again, non corrected, I think)
The Sol-Ark does say that the DC (per MPPT) input is self limiting to 20A, so I'm assuming that if my parallel amperage (whether it be 10.92 ISC Orr 10,34 IMPP) it should be ok to be slightly over 20 amps total, allowing me to run 2 parallel strings of 6 panels wired in parallel to another string of 6 panels?
Do I need to fuse between panels or install micro-inverters if I do the above scenario?
I am hoping to run 12 total Mission Solar 345w panels into each MPPT, eventually, for a total of 24 panels into the Sol-Ark 12k.
For now, I would like to run 12 Mission Solar 345's into one MPPT and use my existing 8 qcell 305w panels into the second MPPT.
Finally, If I can run series, parallel, 6 and 6 into the MPPT, will I need to increase the size of the wires from the array to the controller due to the increased Amperage? I am currently using "standard PV" wire (that's what it is marked, I did not see a AWG label) its the "standard" size that fits into the MC4 connectors.
I am attaching two photos. Specification Info for the Sol-Ark 12k and one for the Mission Solar 345w panels.
ISC = 10.92A
IMPP = 10.34A
sol-ark input max:
or
