Hello,
I've built a power system that will later be used in a camper van consisting of 300Ah 24v battery bank, 250A Daly BMS and Sigineer 3kW inverter. The inverter has ability to communicate with a BMS module, but I am not sure how to do it. I've contacted the manufacture, they say there is no way for the inverter to communicate with Daly BMS, but before I officially give up, I wanted to give it one more try. Maybe someone has knowledge about an existing device that can maybe get the data from the BMS, encoded it and send it to the inverter for it to understand. Unfortunately I am not experienced in programing or so won't be able to create one myself. Manufacturer did send me a pdf with RS485 communication protocol between Sigineer inverter and lithium battery, plus I found Daly Can protocol pdf, but none of it makes sense to me unfortunately.
Anyone has any suggestions?
