Well, since the loctite is wicking up the screw, guess what? It's wicking on the terminals.
I can see a little but I will clean all of the terminals with acetone and scotchbrite and wipe a little noalox on
So you’ve abandoned the the Helicoils and going with SS grubscrews Loctited in with red loctite, right?I wiped off the tops of the terminals with a rag damp with acetone. That took the excess off.
I'll wipe them again in a few hours to be sure there's no residue.
I didn't abandon the helicoils. I just want to limit the number of helicoils I have to put in.So you’ve abandoned the the Helicoils and going with SS grubscrews Loctited in with red loctite, right?
What will be your torque goal for this solution?
From what you’ve seen of the red Loctite so far, do you think it would be effective to recover partially-stripped threads? (Top 3 out of 5 threads barely grab)?
Do you think it was cell movement that messed up your threads or use/galling?I didn't abandon the helicoils. I just want to limit the number of helicoils I have to put in.
I have come to the conclusion that 30 - 35 inch pounds is good enough for the torque. But the threads shouldn't rip out if I accidently go to 40 inch pounds.
I'm glad this problem with stripped threads came to my attention now because they could cause big problems if left unnoticed.
I bet there are a lot of EVE battery packs that have threads already stripped or are ready to let go and people don't even know it.
I am not the only person that has stressed the crap out of the terminal threads by the cells moving.
There was plenty of warning about cell movement stressing terminal threads but I still messed it up.
So you got thread damage before you’d ever removed a bolt or a stud from the aluminum threads? Yeah, must have just been movement/mechanical stress through the busbars then...I think movement messed up my threads.
I didn't turn the stud so galling didn't mess up my threads.
A few of my nuts got stuck on studs but I noticed it when I tried to take the nut off.
It was right after the short. When I noticed one was seized, I checked them all by loosening them.
I just mentioned it because I realized it could be a bigger problem if someone didn't notice.
That is an excellent solution.Glad I’ve settled on 2/0 cables to replace my solid busbars...
I was worried they’d cost a fortune but really not too bad (if you crimp your own).That is an excellent solution.
I have a good cell that needs a helicoil. The helicoil I tore out was on a bad cell I will never use.You had the one damaged thread into which you installed a Helicoil that then sheeted out (at 80Nm). Do you have any other weakened / partially-stripped threads you are trying to recover with Loctite?
If I wanted to fix that hole I would have to use a keensert or timesert now that it is too big for a M6 helicoil.How are you going to attempt to recover that sheered thread, with a larger-diameter Helicoil?
Cool. Have you seen enough to know an M6 Helicoil will be able to recover any future stripped threads your forced to deal with?I have a good cell that needs a helicoil. The helicoil I tore out was on a bad cell I will never use.
Great, so sounds like you’re convinced there is a 2-stage recovery plan for these weak aluminum threads we are getting:If I wanted to fix that hole I would have to use a keensert or timesert now that it is too big for a M6 helicoil.
Or I could put in M8 threads
yesCool. Have you seen enough to know an M6 Helicoil will be able to recover any future stripped threads your forced to deal with?
These crappy terminal holes really aren't a big deal. Just part of DIYGreat, so sounds like you’re convinced there is a 2-stage recovery plan for these weak aluminum threads we are getting:
Primary plan is Stainless Grubscrews w/ Red Loctite
First recovery if those sheer out at 4nm (or whatever torque) is M6 Helicoil
Second recovery if an M6 Helicoil sheers out is Keensert or timesert or tapping M8 threads.
Believe I’ll be following in your (thoughtful) footsteps...
Your confidence is comforting. And thanks for all the good work.yes
Thanks,Your confidence is comforting. And thanks for all the good work.
Nice!I let the loctite cure for 36 hours before using scotchbrite to scuff up the terminals and adding a thin film of noalox to all of the terminals.
Then I wired it up serial so I can do a capacity test. This is the first capacity test for the battery.
I only torqued my busbars to 25 inch pounds. I think it is better to let the threadlocker cure longer before using more torque. And I don't think it will hurt anything. This will force the studs to be normal to the terminals before the threadlocker is completely cured.
Here's my cells barely out of the knee. I have some of my house loads connected but they don't amount to a whole lot. I am usually at less then 10A. Occasionally I get up to 40A or so. It will be days before I hit the low voltage limit and know what the capacity is.
There is a new 225A Class T fuse in the lower left corner next to the cells. The holder can use up to a 400A fuse and I might switch to that one day. The 225A fuse should be good for using two 48V batteries at once.
I only waited 18 hours. The instructions say to assemble right away. But studs allow the option to wait before torqueing.Nice!
My stainless 20mm studs just arrived tonight, so I’m just waiting for you to give Red Loctite your final blessing before getting some and following in your footsteps.
After only 36 hours of cure, you’re able to get to 25 inch-lbs without issue - how long will you wait for ‘full cure’ and at that point, if you plan to push torque further (and if so to where)?
The only thing I check for is heat with a Seek infrared camera. It will show hot spots.Do you have any way to measure the quality / resistance of your connections to assess whether they improve at higher torque?
I do have confidence in those #s but I don't have much experience.I suppose measuring voltage across cell terminals at two different current levels allows you to get some measure of the pair on connection/contact resistances added to the internal resistance (of ~0.25 mOhms).
If you see different deltas in voltage drops (between the two current levels) amongst cells at 25 inch-lbs and any cells you bumped up to 35 inch-lbs of higher, you’ll know the extra torque improved the connection).
Is that ‘cells wire resistance’ a measure you have any confidence in? It’s showing a low of 121 mOhms and a high of 145m Ohms.
I think wire resistance values are very different from IR values.That’s values are very high compared to internal resistance of well under 1 mOhm (which is why I asked if you trust them), but that ~20% variation could be partly explained by differences in contact resistance at 25 inch-lbs...
