Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,761
It has to charge to a high enough voltage to re-synchronize.
I don't think 48V nominal, 24 cell VRLA settings allow voltages that match LiFePO4 top and bottom voltages.
I think some other nominal VRLA settings will accomplish that. Should be able to get max voltage suitably above the knee for balancing, and min voltage suitably below the knee to use most capacity without completely draining.
That's just number of cells and cell voltage settings. Whether SI considers Peukert and allows lower voltage under heavy load, I don't know. If not, apparent SoC would snap back when lead-acid is not under load. Lithium has lower series resistance.
Would like to have a protocol converter, so other brand BMS are made to emulate REC which SI understands.
There are going to be so many different lithium brands and chemistries, and a BMS is required anyway to access individual cells, so it makes sense for BMS to communicate with SMA. If SI only looked at pack voltage it would not know if there was a runner, and charge current/voltage needed to back off and allow balancing.
