Zwy
Emperor Of Solar
@Zwy You have no hope for the 6500ex?
None. There is a reason Signature Solar is offering $750 credit towards the purchase of the 18Kpv unit and you get to keep the 6500EX.
The 18kpv needs some more time to mature?
Yes, it does. Plenty of promises, whether those promises come to bear fruit is another thing. It does appear to be a work in progress.
SolArk 15K is more mature?
Most definitely but has been on the market longer. I do believe they actually ran tests on the product in real life situations before releasing it into the wild. The 18Kpv? Not so much testing as you see threads where this should have been addressed before release.
The 250W limitation of the MPP LV6548 will complicate the design.
Only if the array is a long distance away like my array which is 420 feet away and it is desired to use 10AWG wire with minimal voltage drop. The workaround for me was to utilize a pair of EG4 MPPT's that are VOC rated for 500V, but I currently have one setting a F01 code in the evening but works just fine during the day.
The LV6548's do have 2 SCC's per unit so a pair allows for 4 PV inputs. If a short distance to array and the right panels, the LV6548 would work perfectly fine as a combiner box won't be needed. Total of 16Kw of PV input. Something like this 365W panel or this 380W panel in a 5S2P configuration per PV input would work great depending on the VOC at coldest winter temp.
@timselectric So 1 Growatt is OK, but multiple unit expansion is where it starts to break down?
Tradeoffs.....
