I need a another inside small pump for my water system. Its job is easy...to be mounted at the bottom outlet of a 150 ga plastic tank and push water about 7 ft to the pressure tank and fill the pressure tank. The PT is standard size. I would use a pressure switch on it to turn it off and on.Later on I might modify the system and it would pump water maybe 10 ft to the pressure tank.The well pump is a totally different setup to fill the plastic tank.
I want a quality rebuild-able pump by Grundfos,Taco, or SureFlo. This pump would not see heavy use. 1 man cabin. What models would you recommend and price is a factor also...thanks
