This might sound a bit mad, but bear with me...
I currently have a shed under some trees but some space on a flat roof that could accommodate some panels. I want to generate a bit of energy to give it some background heat and power some other small items. It seems crazy to be spending money to heat it on a sunny day (it's cold due to the shading.)
So my idea is to have a small off-grid system. But also thinking of the possibility of expanding it and making it on-grid in the future.
After looking at some off-grid kits, it seems much more efficient to design your own... Would something like this work? I'm prepared to be told that this combination of items is ridiculous...!
2 x 400w solar panels
1 x 800w charger/inverter
1 x 100Ah lithium battery
Any advice would be appreciated!
LONGi Solar Hi-MO 5m 400WP Full Black PV Module LR5-54HIB-400M
LONGi's high-efficiency PV modules are widely used all over the world, from alpine grasslands to desert wastelands, and from ponds and vegetable beds to household dwellings. LONGi's ultra-high-value PV module products continue to benefit customers and local economy with its advantages of "higher...
www.cityplumbing.co.uk
All-in-one Inverter Built in 800W 12V Pure Sine Wave Power Inverter & 50A Controller for Off Grid System | ECO-WORTHY
If you are looking for a hybrid kit, ECO-WORTHY 570W 12V expandable hybrid kit is an ideal choice. This system should be enough to power a tiny home or a super-efficient small home. A 400W wind generator produces about 60kWh per month in 10.5m/s average winds. ECO-WORTHY 170 Watt 12V Mono solar...
uk.eco-worthy.com
LiFePO4 12V 100Ah Lithium Iron Phosphate Battery | ECO-WORTHY
ECO-WORTHY LiFePO4 12V Lithium Iron Phosphate Battery has twice the power, half the weight, and lasts 8 times longer than a sealed lead acid battery, no maintenance, extremely safe and very low toxicity for environment. Our line of LiFePO4 offer a solution to demanding applications that require...
uk.eco-worthy.com
