After having a pretty good run with two JK bms’s, I added a third bms & battery for 16 cell batteries. The first two are are models JK-B2A24S20P (24cell version) and the only issue I can see is some strange occasional “Abnormal release of current sensor” in the log file but doesn’t seem to have any affect in functionality nor alarm so I ignored it, also with the third battery it seems to be gone. The new, and perhaps problematic is the JK - B2A20S20P (20 cell reference now on). The first two took about 5 cycles to learn what 100% full SOC (state of charge) was. Curiously, the new 20 cell read 100% on the first charge. Things looked great for the first week then I started to notice it’s divergence from the first two and up to 12% deviance. Now I understand that the batteries can charge and discharge at different rates but full is full and when they are all at the same voltage at the top, I’d think that, that would be the only time that they’d be having the same readings of 100%. None of these bms’s have ever seen anything more than the full, bulk, end of charge 55.2 volts. They all get to full charge at least once every 3 days. All are nicely balanced charging and contributing perfectly. The only thing that is a problem is my OCD when I don’t ever see the Solar Assistant get to 100% because it uses the average of the three batteries. I’ve re checked the voltage and current adjustment in the app to reality and it’s correct. The only thing I can think of is the new bms has a different algorithm that wants to see more absorption time (that it’s not gonna get). Typically it runs up the knee, current drops off, holds at 55.2V for 15 to 20 minutes, releases and drops to 54.4 float as long as the sun can hold it there. Rinse and repeat every day. Already ordered a new 24 cell JK. At least the layout in the apps will look the same since data is presented in different order between the 24 vs the 20 cell. Any ideas? I wish that JK offered a “set state of charge” like other brands.![IMG_0833.jpeg IMG_0833.jpeg](https://diysolarforum.com/data/attachments/158/158883-ca7f9f8233d9c17e014f260b2c3af19f.jpg)
