Why?
- Copper busbars on alu terminals. That is not ideal at all. Did you use noalox or carbon grease ? Terminals polished ?
How can you tell those are copper bus bars?
It is a universal check list Just guessing.
But manufacturers usually give Nickel plated copper busbars to cells.
And aluminium is a bit more sallow/matt. Like the ones that make the series connection here.
The bus bars between the cells and the bus bars between the parallel sets are different. Different metals? Who knows. But I do wonder if the bus bars were up to the number of amps that the battery bank could produce.
I will bet the first and last bank RAPIDLY became dramatically over charged, bloated and count the entire bank on fire…He was so proud of his new 48v parallel series configuration. Charging the cells up...
How it ended up:
Crank the brightness to see this aftermath photo a little better:
I don't know what caused it, but he was not using any bms. I believe the inverter was a Grow Watt.
Wow… look close at the before picture… notice main positive and main negative are NOT connected to the parallel set… a fire from the omission of two bussbars…
They are however the ones with the ends of the case burned out…So they should have swelled. And yet, those aren't the ones ripped out of the pack.
I'm having trouble seeing what the issue is, could you draw on the image itself to point out exactly what the issue is?Wow… look close at the before picture… notice main positive and main negative are NOT connected to the parallel set… a fire from the omission of two bussbars…
Look at the before picture… notice where he has the cables connected to the cells… there is a space between the terminal with the wire and the rest of the paralleled cells…I'm having trouble seeing what the issue is, could you draw on the image itself to point out exactly what the issue is?
Also seems like it would be wise to not pack parallel banks directly up against each other simply to reduce chances of an issue physically spreading to all the banks.
It kind of looks like he started out making 4p and then switched to 5p. Notice that a single bus bar covers four cells and then another bus bar is used to extend to a fifth cell.
LFP is safe. The haphazard way some people use the technology is what's not safe. A 5p16s battery is like playing Russian Roulette. A 5p16s battery without a BMS is like playing Russian Roulette with a bullet in all six cylinders! Murphy never sleeps.
I am wondering if the other 8 cells got any charge at all, so maybe those survived the fire? It looks like they didn’t swell at all, the ones closest to the main ones got toasted bad, but maybe a few survived?
