Checkthisout
Solar Wizard
- Nov 14, 2021
- 4,810
Unable to start. I suspect that if it got past the surge it would be fine. The issue might be, as others have noted, the voltage drop from the batteries. But I'd say three 24V 100AH Amperetime batteries, properly wired with 2/0 cables, is a reasonable, somewhat typical installation for a small, off grid building with loads typically between 100-150 watts and just occasional need for a "big load", like this small log splitter. So, whether it's the inverter or, perhaps even more likely, the batteries behind it, this was "no joy" situation that having a low-frequency inverter didn't resolve. Still to be seen... What happens on shore power, with the same inverter.
Yeah, it should start it. It's going to be hard to measure a voltage droop from the batteries that is that short in duration.
I would make sure all the batteries are on and outputting.
Also, load test the MP with a couple space heaters and check all your connections etc.
It should be able to hold about 2400 watts constant.
