OffGridForGood
Catch, make or grow everything you can.
The cost doesn't seem to be less on Aliexpress, but now I see Individual Sodium Cells available...humm
oh for USA at least it's quite a bit cheaper for cells there than alibaba + shippingI typically use Aliexpress for low cost (low risk) items.
Alibaba is better for larger cost items, more protection if anything goes sideways.
All that said, these are not high cost items, maybe it would be cheaper via Aliexpress, now I feel like I have to go look!
nice good luck. Finland definitely a place that could use better cold-resistant batteriesI've got a few coming to my lab soon-ish. I'll test them when I find time.
i don't buy cells on aliexpress.oh for USA at least it's quite a bit cheaper for cells there than alibaba + shipping
I would have thought almost certainly the X axis on the graph is linear and represents time during a constant current test. You’re right it’s unclear because it’s not stated, but this is standard for cell testing reports.Although the we don't know the X-scale in used the image charge/discharge image, I'm assuming that it is linear. The corresponding voltage curves of a capacitor are logarithmic, and there would be "a lot of weirdness" in in pulling power from parallel devices of the two types.
<snip>
If I may view the graph with a linear X-axis corresponding SOC percentage, a 4S battery pack of the soldium ion cells, however, would only offer 'nearly 220AH' of power storage if allowed discharge from more than 15.6 volts (at high SOC) all the way down to around 8.0 volts. The discharge curve would fall below my minimum of 2.8 volts when about 40% of the battery remains unused.
Yea basically nothing on their CCA rating yet. There are batteries that also have capacitors in them so that takes the initial high amp hit...I wonder if the low temperature capabilities of these new sodium cells and their potentially much lower costs compared to lithium might make them suited to replacing lead acid as car starter batteries? LiFePO4 never quite made it into that application, but are sodium cells going to be better suited or are the CCA cold cranking amps requirements just too high and lead acid will remain the best choice?
What parameters are you most interested to test?I've got a few coming to my lab soon-ish. I'll test them when I find time.
Keep posting - very interested to see what you find.Pretty much everything I can. Stress test, voltage curves, a couple of destructive tests (short circuit, etc.). We'll see what I have time for...
Will you put it outside in minus 60-degrees C and show us what happens?!
The net energy will be the scale to evaluate: if an energy storage system needs to use a portion of that stored energy for temperature regulation with Lithium, but does not need temperature regulation with Sodium - this will be a huge impact.There seems to be some relatively serious investment going into sodium batteries.
At this point, it looks more feasible for large energy storage projects, though the 5000 cycle is considerably less than Lithium provides so it seems like there would have to be a very substantial cost offset.
Time will tell.
Sodium in Batteries: Shift May Herald Another Shakeup
Battery giants are starting to put their money on new sodium-based technology, a sign that there could be yet another shakeup in the industry that’s crucial for the energy transition.www.bloomberg.com
Do you have an inverter in mind that will work with the wide voltage range of the sodium cells? Curious.I really don't care what people have to say about the need for new charging methods. I intend to build a daily commuter car for my 10-mile round-trip for work. It'll have dual 48-volt banks that get connected in series when the car is powered up. I'll charge it from my home battery bank and each will have a 16-S BMS. Given the voltage range of the cells, I don't see why I'd need to be concerned. My home solar can't exceed the safe voltage and the cells are good down to 1.5 volts. I believe that people are over-thinking. I'll be staying well within the voltage range and be able to charge my car without pre-heating the battery packs. If there is a legitimate concern that I'm overlooking, I'm very receptive to constructive criticism. If it's that I'm wasting the potential of the cells, this is not my concern.
Each BMS will be 32s. I intend to use two of the same BMS that I would use for a 48-volt LiFePo4 battery. My home battery system is Lead-Acid and, when either or both of the 48-volt banks is switched to the charging position, it will disable the ignition switch and each car battery bank will charge directly from my home batteries and from the off-grid inverter. I see no reason for the need of any inversion. I have enough DC electrical knowledge to wire this up. My only concern is finding the appropriate contactor. There is little need for more than 96 volts in my city car but I'm aware that the upper end of the battery voltage will hit 117.2 volts when all of the batteries are connected because my home system is charged at 58.6 volts. This 3.6625 volts per cell is well within the safe range of the Sodium Ion cells. Still, I know that I'm only human so it is possible that I haven't considered all factors. As for DC to DC for 12vdc accessories, that should be simple enough. If anyone thinks to warn that the charging characteristics of Lead-Acid could cause damage to my new cells, I've thought about this and have purchased a device explained in this video.Do you have an inverter in mind that will work with the wide voltage range of the sodium cells? Curious.
ie 16s @ 1.5 volt = 24v, if you series two packs = 48v at the low end, but at the top end 4v x 16 = 64v and series connected x 2 =128 volt,
How will you utilize 48 to 128 volt range?
Interesting,
what motor do you have in mind for this project?
I hope you post your build and how it performs, interested to see the result.I explained to the salesperson that I want to be able to reach and maintain 55 mph for as much as 7/10 of a mile 10 times per week without harming the drivetrain. This is the kit she suggested.15kw High Rpm Induction Motor For Electric Kit - Buy High Rpm Ac Gear Motor,15kw Plug In Hybrid Car Conversion,20hp 15kw Electric Motor Product on Alibaba.com
15kw High Rpm Induction Motor For Electric Kit - Buy High Rpm Ac Gear Motor,15kw Plug In Hybrid Car Conversion,20hp 15kw Electric Motor Product on Alibaba.comwww.alibaba.com
