HighTechLab
AKA Dexter - CTO of Current Connected, LLC
- Sep 23, 2019
- 1,691
Sometimes, you just have to ask the community, WTF???
Quote from customer inquiry:
In my mind, the battery cannot create a voltage this high, and if it could, it would have been on fire a long time ago...Any speculation or thoughts on how a battery that is disconnected could be reading a voltage this high? I'm out of ideas. I suspect it's the low-cost meter, but how can a meter be a full order of magnitude off?
Any suggestions much appreciated.
Pictures - Meter testing good battery showing 10.7v and on "bad" battery showing 125.9v with the same settings
We had one battery reading 112v. He placed the battery outdoors. This morning the battery is reading 125v. We checked the voltage meter against several other batteries using 4 voltage meters. Only one voltage reader would read up that high, the other 3 meters would not read. We moved the battery farther from the house due to the increased reading when we expected a drop from being out overnight.
Please advise us as to what to do with this battery. If it has a short, should we attempt to lift the top? Do we have any other options or just wait for it to catch fire?
