Hello, I have two physical Sol-Ark 12 K units. 1 has 12000 watts of panels, one has 1920 watts. When is parallel setting there is a 3rd sudo plant created that combines the two plants so you can watch your system as one. in power view this sudo would be found under plant list.
There are not a lot of parameters to set for the sudo plant. however there are some, one in particular I am not sure how to calculate.
Based on the total solar panel wattages of 13920 (unit 1 = 12000 and unit 2 = 1920) what should the kWp be set at?
