timselectric
- Feb 5, 2022
- 18,589
I believe it's just an on and off. Not a variable control.This implies that when you have power exceeding the loads on the critical loads panel that power will flow into the Sol-Ark. this must mean the load out connection also allows power in. This implies it will flow back into the main service panel and off into the grid. OR it is used to charge the battery. What happens when The solArk is set to not export power and the battery is full. In this case the frequency gets shifted to turn down/off the microinverters. Is there a table to correlate frequency shift to %power generation on the microinverters or is this just an on/off situation?
It's based on battery SOC.
If I'm not mistaken. It's off, at 100%. And on, at 90% or lower.
