CURRENT SETUP:
Because the Fronius inverter and the 100amp subpanel are so far from the main I can't directly bypass the Fronius inverter and run the solar DC lines directly to the Sol-Ark's MPPT inputs. So I don't see any way to directly measure or monitor the PV outputs thru the Sol-Ark app or software. Right now I use the Fronius app to measure realtime and historical PV output, but it is just information only and not a management tool.
Any ideas on how to overcome this shortcoming?
Thanks in advance.
- I have 7.92 kW grid-tied array running thru a Fronius Primo 7.6 DC inverter selling any excess production back to utility
- This system sends the AC power that it outputs to a 100 amp subpanel in a barn, about 150 feet from the 200 amp main panel
- The subpanel is connected to a 100amp breaker in the 200amp main panel which is in the house basement. So the solar production goes from inverter to subpanel to main to grid.
- The 100 amp barn subpanel also has a bunch of other stuff that it is powering: barn lights, tools, pool pump, etc...
- There is also a 30amp generator hookup in the barn that feeds to a 30amp breaker in the main panel (I turn off the main breaker and use the interlock to ensure no power flows to grid in an outage). Currently, this is how we get power when the grid goes down, which it does 3 or 4 times per year. This generator also is tied to a relay so that when it is running it does not allow power to backfeed to the subpanel and inverter.
- Sol-Ark 15K with 15kW of Signature Solar batteries in a server rack
- Plan/thought is to Wire it this way: Meter directly feeds to GRID connection on Sol-Ark. LOAD connection on Sol-Ark connects to main 200amp breaker. Move the 30 amp wire from the generator from the 30amp breaker on the main and TO the GEN connection on the Sol-Ark.
- My goal is to eliminate and/or reduce the need to use the generator and instead seamlessly switch to battery provided power in an outage. I also will want to use the batteries to power the house at night and then re-charge when the solar array is producing...the classic sort of management that people are doing with the Sol-Arks. In the case of a prolonged power outage I'll fire up the generator and recharge the batteries that way.
Thanks in advance.
