Tulex
Solar Wizard
Sol-Ark 15, two batteries with 200 amp Seplos bms.
Played around with some of the Seplos settings. At some point, the settings in the BMS app changed my Sol-Ark charge settings.
For Float, I'm trying to set 55.7v as per the latest example in the Sol-Ark manual. It takes the setting, but then it keeps going back to 58v
For Absorption, I set 56v, it goes back to 58v
for Equalization, I set 56v, it goes back to 58v
I don't have anything set that high in either bms.
Also, what parameter actually tells the battery the voltage to charge to?
