They run at 208/230vac, so I have to account for a split phase inverter setup when considering both up front costs and power consumption. They're both ~$1500 - slightly less than the DC units I've found. The consumption on those, though, is prohibitively high
With the popularity of RV boondocking, I have a lot of interest and I think there is a decent sized market for effective DC high efficiency mini-split AC units for solar powered mobile applications. I think the OP's idea is more applicable to the mass automotive market, but I'm not sure how big that market is, and with electrification of more and more cars, it may be shrinking.
I have a couple questions related to the above comments.
1) do you think the units really need a split phase inverter, or would a single phase 208/204 V work? I could see the importance of split phase if you were depending on the same inverter(s) for your 120V needs as well, but if the inverter were dedicated to the mini-split, it seems like single phase 220-240V would work probably work fine, unless the units need the neutral connected.
2) Do you think the HotSpot unit has higher draw because it is less efficient, or just because it is a much larger capacity (12k BTU) unit. I'm not sure that it takes more Wh to deliver the same cooling as the smaller units, if it is only being asked to deliver 6-8K BTUs. It would seem that the inverter losses would more than cancel out any advantage the smaller units might appear to have.
I think many on here who are scheming around mobile off-grid living quarters may be a slightly different market than what the OP is targeting, and many of us have started to embrace a higher voltage system as one way to overcome the challenges of huge current at 12V, hence all the comments about 24V offerings being preferred.
I'm currently acquiring supplies to bring my RV up to about 17kWh total battery storage with 1200-1400 watts of PV. I've been steering towards 48V and thinking of the Hotspot, but since I would probably be mostly concerned with cooling the rear 7x8 ft bedroom, 12k is probably serious overkill and I'd expect to be running the unit at much lower consumption than the rated consumption at full output.
The Dometic Truck Coolers posted above look very interesting depending on the price as it would be dead simple to swap out my bedroom fantastic fan for one of those. It surprises me that their website only shows 12V offerings coming soon, but says much of the testing was done in AUS. I would think a 24V model would be the norm there.
