SenileOldGit
- Oct 15, 2022
- 320
Hi, I have two MPP Solar PIP5048MKX inverters, and have connected them to a Raspberry Pi running Solar Assistant, each inverter has its own USB cable connected to the Raspberry Pi (admittedly by 15m of 'active' USB extension cables). Solar Assistant says that only one of the inverters is actually connected to the Raspberry Pi's USB port, the other is being read through the parallel connector of the second inverter.
I also use MultiSIBControl with the same USB cables, and that shows both inverters correctly, and shows all their information. If I remove one of the USB cables from my PC, then when I restart MultiSIBControl, only the other inverter is visible, so I am pretty sure it doesn't attempt to read data from the parallel cable of the USB-unplugged inverter. So I am pretty sure the USB extension cables are working fine. So I was wondering why Solar Assistant only sees one USB cable correctly on the Raspberry Pi.
I have tried unplugging one of the USB cables from the Raspberry Pi, and Solar Assistant just reads the unplugged inverter's data through the parallel cable, into the connected inverter.
I get strange battery readings from Solar Assistant, it always shows something like 3,000 watts coming out of the battery, almost never anything going in, even though if I switch the USB cables over to MultiSIBControl, it shows the inverters are providing a kilowatt or two to the batteries. Has anybody else had this problem?
