What's the specs on that blanket?Testing this newly got solar blanket.
By covering only about 6% ie one half of any cell, the output current would drop by 50%.
Is there hat normal?View attachment 42950
it is a 350W solar blanket for $260, but I don't think it comes nowhere near its spec'd wattage. I tried using a mppt and the regulator it provides, it delivers no more than 8.5 A on a clear day with good sun, I can't see how it can ever deliver anywhere near 350W. It is going back to the seller, I am afraid.What's the specs on that blanket?
Price?
thanks
How come they aren't called solar sheets?
That is the pwm as supplied. I also used a Renogy mppt later, similar result.Length and width of the portions holding the cells?
Are you absolutely certain that you're using a genuine MPPT SCC? Lots of fakes on the market, and that tiny thing sitting on top of your battery does NOT look like a legit MPPT.
I would feel better owning a solar comforter. Bah dum bump.How come they aren't called solar sheets?
How many Amps Renogy?That is the pwm as supplied. I also used a Renogy mppt later, similar result.
Max Power: | 350W |
Max Power Voltage: ( presumably VOC ) | 18.4V |
Max Power Current: | 19.02A |
Not Voc.By this calculation the total panel surface area is made up of 8 pieces of 32 cm x 32 cm tiles, so the max power output should be about 0.16 W, that does not make sense either. Sure it is delivering much much more than that. Something I miss in the formula ?
Claimed parameters are
Max Power: 350W Max Power Voltage: ( presumably VOC ) 18.4V Max Power Current: 19.02A
Comments ?
I used a Renogy dcdc50 with mppt to test as well.Shame it is nowhere near 19A. Tagging this to watch and see if you decide on a better mppt controller to try and get at least 15A.
Each of the 8 panels should be about 43 watts for 350 watts total.By this calculation the total panel surface area is made up of 8 pieces of 32 cm x 32 cm tiles, so the max power output should be about 0.16 W, that does not make sense either. Sure it is delivering much much more than that. Something I miss in the formula?
For a comparison, this is the unfolded dimension of the 100 watt panels I have that will slightly exceed the rated output maxing out at around 104 watts:Ok so how big is a real 50w panel or 100w panel compared to that?
32cm x 32cm is about 12.5" x 12.5"
Where did you buy the blanket from? Sales link?
