I have a 12.8 kWH grid tie solar system on the roof currently. It doesn't provide any power in the event of power outage. I need to provide power for a few appliances via a stand alone solar setup. I would like to run them full time from solar / batteries unless the bank goes below a set voltage and then switch to conventional power. Usually power outages are only a few hours here. Load would be a 25 cubic ft household Fridge, a deep freezer, fish tank with 1 pump, and a laptop / monitor. I think it's about 500 watts when everything is running, but the fridge won't run constantly.
I have purchased the following.
2 ZNShineSolar 450 watt solar panels
1 2 panel roof racking system
1 MPPT solar charge controller (80amp)
1 100 ah 12v Renogy battery
1 200 ah 12v Renogy battery
1 1000w inverter (generic brand, not pure sine wave) looking for recommendations for replacement
50ft 10 awg solar extension wire
10ft 10 awg solar wire
2 40 amp DC circuit breakers. One between the panels and the MPPT controller and the other between the controller and the batteries
1 50 amp fuse between the batteries and the inverter
I have the panels mounted on a shed, wires ran to the basement and connected to the MPPT controller, inverter and batteries. I think the next step is to purchase a Automated Transfer Switch and pull the wires from the breaker box in the basement and route them to the ATS, pull power to the ATS and connect it to the battery bank.
What ATS recommendations would you have, is there anything wrong with my initial design?
