Hi all,
This is my first ever solar system. I have the following:
- eight ET Solar Group ET-P672280 (280W) solar panels in series of 2, 4 series parallel
- one ECO-WORTHY 4 String PV Combiner Box with Lightning Arreste, 10A Rated Current Fuse and Circuit Breakers 63A.
- one growatt Off Grod Solar Invetter SPF 3000TL LVM
- 2 simpliphi 48v batteries.
Please see my diagram below and critic if you can. I have not yet drawn in the ac breaker. And the fuse coming from the battery should be rated at 80a, not 100a.
AccESS™ with PHI™ Batteries and SimpliPHI® Inverter
<p>AccESS™ with AmpliPHI™ 3.8kWh batteries and industry leading SimpliPHI 6kW Inverter is a fully integrated and pre-programmed energy storage and management solution. With closed-loop communications between inverter and batteries the system can self-monitor, provide backup to essential loads...
simpliphipower.com
