Hello,
I work at a farm and we need to power a compost sifter.
The sifter uses 2 electric vibrating motors to shake the sifter. Each motor is 100 Watts.
I have researched building my own unit or buying a pre-built station designed for camping and getting a panel to charge it.
Here are the stations I was looking at.
Is a 300 watt station enough to power the sifter or should I get something bigger?
Whatever I use it need to be portable, able to use outdoors in the heat, and under $1000.
I have no experience in solar and very little in electric builds.
Any advice is appreciated.
Thank you.
Wattfun Portable Power Station, 96000mAh/298Wh Regulated Voltage LiFeP
Super Compact And EfficientWattFun is not only the most compact power station in the market, but also features as huge capacity as possible.It has such a large capacity of 298 Wh (96000mAh), and can easily meet all electrical needs of your devices which less than 320W. It will fully charge...
wattfuns.com
Togopower Advance 350 Portable Power Station
Outdoor Camping Battery: Togo POWER 350W Portable power station specially designed for charging laptops, mini-cooler, drone, and other outdoor electronics. 346Wh high-density lithium battery packs, enough power to work CPAP(12V) for 3-4 nights, Be sure to use a DC-DC converter. And the DC 12V...
togopower.com
Thank you.
