Solar Panel Compatibility Keystone OEM and Rich Solar Mega 24V Panel
upontheridge
NC
I have a Keystone RV with the Solarflex 200i system. The panel that came with that system is an OEM-exclusive panel. Specs on the back of the panel are below along with specs from Rich Solar Mega 24v Panel. Are these panels similar enough to use together and if so, would you recommend connecting them in parallel or series? The wiring from the Jaboni port on the roof to the SCC is 10-gauge wiring. The current SCC is a Victron75/15. I will upgrade to 100/30 before installing unless a 100/50 would be recommended.
Panel ModelKeystone 0EM made by Allesun-200-3611Rich Solar Mega 24V Panel
Rated Maximum Power (Pmax)200W200W
Voltage at Maximum Power (VMP)41.70v37.6v
Current at Maximum Power (Imp4.8a5.32A
Open Circuit Voltage (Voc)49.8v45.4V
Short Circuit Voltage (Isc)5.09A5.83A
Tolerance0 to 5%
Maximum System Voltage1500vdc1000VDC
Maximum overcurrent protection15a15A
Dimension10.75x39.45x1.3858.7x26.5x1.4
Weight26.46lbs
26.5​
What is the coldest weather the panels will EVER be exposed to?
100V doesn't give you much clearance with a 49.8 and a 45.4V panel...
100/30 is OK. Connect the panels in parallel.
An option would be to add a second 75/15 just for the second panel, and have the controllers operating in parallel. This would allow maximum yield under all conditions.
parallel.
parallel.
Adding the wiring for a second SCC would be a complicated process with my RV configuration. I was planning to use the 75/15 controller for a third portable panel. Would you recommend going with a 150/30 SCC or will the 100/30 be sufficient.
