The below diagram shows a 2s3p & 3p2s solar configuration respectively(at least I think that's what the configurations are called). I wired my 6 solar panels using the bottom example(3p2s) but afterwards I realized that I could wire them in a 2s3p configuration(top example).
Are these pretty much the same? Is there any benefit of going with one configuration over the other?
After reading this blog I believe both configurations need to be fused where the 3 hot lines come together. So the top example would need fewer fuses.
Otherwise, I think they're pretty much the same and will preform the same in shady conditions. Am I missing anything? Thanks.
Each panel is 240w. 38voc, 8a. 15a max fuse rating"
