learning all the time
- Nov 8, 2019
- 145
Hopefully my title sparks interest. I am running 500w of solar panels. 2 renogy eclipse hard solar panels and 3 rich solar flexible panels. The renogy I have had for two years and the rich solar I am in the process of adding. The two renogy and 1 rich solar connect to my mppt controller without problems-- a little inefficient but that is a flat roof problem I believe-- two of the rich solar panels do not connect. I get 21.5 voc on both and 5a imp. When I try to run these in parallel I lose voltage and amps. I tried running the two rich solar each indivually and the controller says mmpt waiting to charge. I tried series between the two and the same thing. I do have extensions on the two bad solar panels but again, everything seems to test good through the connectors. Any thoughts or ideas or another test I can try? All help is wonderful.
