joesmith123
I need to mount tons of solar panels on top of a shed
Also, I do have a prius generator now going into a 6000 watt sungoldpower inverter
Few fundamental questions:
How do I wire it to take power from the solar panels AND the prius high voltage?
I need both power sources (prius and solar panels) to go into a battery bank that is big enough
Anyone have a reliable way of mounting the solar panels without putting holes into the roof?
I did see standing seam brackets that put holes sideways instead of going into the actual roof
What size battery bank do you recommend for this situation? It is about 900 sq feet of intense sun
Thanks in advance
Thanks in advance
