Solis Techview
bigmadstu
Hi, first post here.
We've just fitted a Solis RAI-3K-48ES-5G AC coupled inverter with a Pylontech US3000C battery.
All working well, it's harvesting the excess off the solar panels and charging the battery. Discharges when the solar output is below the house usage.
I have the "Techview" app on my phone and can connect to the inverter's wifi. This allows me to monitor it's status etc. However I understand the app can also be used to change the settings on the inverter. There is an "advanced user" and "installer" login. My question is "does anybody know what the passwords for these are?" The panel on the inverter has a password for settings which is the default "0010". The app doesn't accept this. Just says "password error"
Hoping it's something I've missed here, lol
I read elsewhere on this forum that you can't send data to the inverter from the Solis cloud servers, but don't use that myself
Yes, the Solis cloud only seems to be capable of monitoring. I rate it as "mildly useful". It's handy to see the graphs of charge and discharge etc. Would be much better if I could tweak the settings remotely though.
We didn't bother with it as I thought it only had a 10 minute resolution. what settings did you want to tweak?
I'd like to set a timer to charge through the night on Octopus Go. Easy enough but I'd like a remote way of tweaking the charge time. Based on time of year and weather forecast.
I've done that with custom code via CANBus interface to our Solis ?‍?, but don't see how that would be possible without such custom integration ?‍♀️.
Thanks, I've read a bit about this. Looks interesting. I've done a bit with vehicle canbus, this looks similar.
I have already tried switching the solis to AP mode and connecting it to the house router. Connects no bother but then the app can't find the server. ( On the solis. ) I suspect the solis has a static IP for it's server which I don't see how to change. ( 10.10.10.1 and subnet 255.255.255.252 ) I'll have a bit more "play" at some point.
One thing I haven't tried yet is setting the charge timer. Looks straightforward but I'm wondering if that mode on the solis cancels charging the battery from excess solar generation. I'll need to set it up and see what it does.
... One thing I haven't tried yet is setting the charge timer. Looks straightforward but I'm wondering if that mode on the solis cancels charging the battery from excess solar generation. I'll need to set it up and see what it does.
Yes, straightforward. Select 'self-use' mode then sub-menu 'Time-of-use'. From there, set mode to RUN, set charge rate if you want to limit charge current and then just enter the time you want it to charge between. e.g. from 01:00:00 to 03:00:00 if you want 2 hours of charging during economy 7 rate ⚡. That's it. All that will happen is between those hours the Solis will charge the battery (and house will be supplied from grid). Outside those hours, everything will operate as usual (i.e. priority = house load then charge battery then only export excess if battery is full and there is more ☀️ than the house load needs). Don't set anything in the discharge period timing though.
The only issue with doing that is the batteries will charge whatever their state of charge. You will need custom code via the CANBus if you want to, charge up to a specific SOC ?, for example.
That's great info thanks. It's a decent inverter this but the documentation does leave a bit to be desired, lol.
Hi, I have the Solis RAI-3K-48ES (not 5g..) and I can't see a 'self use' mode inside the storage settings. I only see 'Timed charging', 'Off Grid mode' and 'Reserve Battery'... Do you know if I can somehow enable this 'self use' mode? Perhaps I need a software update.. Thanks!
Self use is the default mode. ( on the 5g at least ) Outwith any timed charging sessions this is what the inverter defaults to.
Hi .. yo have two passwords, depending on if you enter like a user or installer...
advanced user: solis123456
installer: solis123
A lot of time for found this pwords, but Techview app is really bad..... :(...
installer: solis123
Thanks for that. They are both accepted... and seem pretty useless. I was hoping for more options in the app but you are correct, the Techview app is really bad.
installer: solis123
Thanks been hunting for this for ages as other have I understand! Agree Techview is next to useless ?‍♂️
What and how does one use the Canbus mode? I'm also changing my tariff to octopus to charge my batteries at night, and also have the 5G Solis battery Inverter. Using the screen or Solis apps is a nightmare in this day and age.
Hi, my first post also.
I have just programmed my RAI-3K-48ES-5G from the control panel to charge on economy 7 but as my inverter is in a loft space it would be far more convenient to use the Techview app. However, firstly I've noticed you need to be almost on top of the inverter to get a decent WiFi signal and secondly the passwords "solis123" or "solis123456" are not working so I can't connect to the Solis WiFi. Any there any other passwords known to anyone?
Is it even possible to change the charge times from the Techview app?
Thanks.
I don't have the "send-all-my-data-to-china-dongle" on my Solis, but from what others have said, no, it is not possible.
Hi you have simalar setup to me I believe you have the passwords now solis123 and solis123456 there is another password you may want 2017 this is the number to input on the inverter instead of the normal 0010 it gives you an additional sub menu.
If I can ask you a question please do you have the Acrel 10R meter? If so do you have more than 1 ct connections into it? Thanks
Can I please ask; when the weather turns sunny and I don't want to charge at night, is it enough just to change "RUN" to "STOP" to prevent any timed modes taking control. Thanks.
On our inverter we will just delete the charge times and leave the discharge times to 00:00 that way it will not charge from the grid on those times but supply your loads.
Hi @Tony_AH. I have just installed my RAI-3K-48ES inverter. After much hassle, I got the Techview app working and you can change the charging times from the app. This is how I got it working...
  • I used a spare mobile phone to run the app. Since the wifi connection is a direct connection between the phone and the inverter, I was having to turn off all internet connections (mobile data include) on my phone simply to connect to the inverter (my phone doesn't like direct WIFI connections as they have no connection to the internet).
  • The wifi password is solis100
  • Once connected, you need to go through the initial setup steps on the app (even though the inverter has already been set up) to get to the charging time settings. After doing this, I went back and checked that all the settings on the inverter are still correct.
The Techview app is not great however, I have found the information useful, especially the graphic of the power flow.
I hope this helps.
I hope this helps.
Hi Geoff, Thank you very much for this information. I have now at last managed to connect the app to my inverter, however, I couldn't remember the first advanced start up answer so will have to check I get them right before I proceed any further.
The signal from the inverter is quite weak so I had to get quite close, but I was able to get my phone connected OK without disconnecting the house WiFi and mobile data.
When connecting to the inverter WiFi my phone warns me it can't connect to the internet and offers to switch to a better network, declining this offer keeps me connected to the inverter.
I assume because you did a self install you are not able to use the Solis Cloud app? I normally use this app to monitor the power flow to batteries, house and grid as it works anywhere I have a phone signal. It's a similar view to the TeckView app but you can see a bar graph below for the power flow for the whole day.
Thanks again.
Not from Techview. But I can do it from the SolisCloud app and website now.
Interesting! So the Chinese can reprogram your inverter now as well, not just monitor all the data you give them :eek:
