bugone
I'm sure if it's sold in the US it would.Does it do 60hz?
I have the RAI and the Cloud app seems to have no concept of the PV being AC coupled even though it has a CT on the PV output - I think the app and ecosystem has been largely coded around hybrid or standalone inverters which is a bit rubbish IMOAnyone using Solis Cloud with this inverter, do you have the PV generation displayed?
On my overview I've got a gap at the top left where it looks like PV could be displayed. Top right is grid, bottom left is battery and bottom right is load.
The inverter appears to be working fine. Charging overnight worked and I was charging today with the excess solar (battery wasn't at 100%).
It's just the app that doesn't have any record of any generation. Today yield is 0 and Current Power only ever showed 0 as well. But I know there was 2kw of solar generation today (via another monitor).
Submit a ticket to Solis support.I have the RAI and the Cloud app seems to have no concept of the PV being AC coupled even though it has a CT on the PV output - I think the app and ecosystem has been largely coded around hybrid or standalone inverters which is a bit rubbish IMO
Does your inverter have the little wifi antenna attached at the bottom? I could well imagine an installer leaving that off.Hi, my first post also.
I have just programmed my RAI-3K-48ES-5G from the control panel to charge on economy 7 but as my inverter is in a loft space it would be far more convenient to use the Techview app. However, firstly I've noticed you need to be almost on top of the inverter to get a decent WiFi signal and secondly the passwords "solis123" or "solis123456" are not working so I can't connect to the Solis WiFi. Any there any other passwords known to anyone?
Is it even possible to change the charge times from the Techview app?
Thanks.
Did that months ago, it sat doing nothing until the guy from UK support contacted me with the user manual for Techview - I then passed on all the weird stuff and it went back to 'head office' apparently - haven't heard back since so not holding my breath but interesting that your experience with the plant registration seems to be the underlying cause - I'll flag that at some point - the only thing I'm using the cloud info for is the SoC value otherwise I have separate monitoring for all the other values...Submit a ticket to Solis support.
I have the same on my display. All my panels use micro inverters under the panels, some EnecSys and some Enphase. I was told that because I don't have a Solis String inverter for the the panels the app wouldn't be able to see the output from the panels. I believe removing this solar feed input (top left) is controlled by the cloud administrators as it was briefly visible on my app then turned off as I don't use their hardware.Anyone using Solis Cloud with this inverter, do you have the PV generation displayed?
You're welcome to quote my ticket number (133683). So the Solis support agent can use the same solution from my ticket. This is for the missing PV Output value in Solis Cloud.Did that months ago, it sat doing nothing until the guy from UK support contacted me with the user manual for Techview - I then passed on all the weird stuff and it went back to 'head office' apparently - haven't heard back since so not holding my breath but interesting that your experience with the plant registration seems to be the underlying cause - I'll flag that at some point - the only thing I'm using the cloud info for is the SoC value otherwise I have separate monitoring for all the other values...
Mine is all micro inverters under the panels. PV now showing fine now whatever Solis support changed on my account.I have the same on my display. All my panels use micro inverters under the panels, some EnecSys and some Enphase. I was told that because I don't have a Solis String inverter for the the panels the app wouldn't be able to see the output from the panels. I believe removing this solar feed input (top left) is controlled by the cloud administrators as it was briefly visible on my app then turned off as I don't use their hardware.
I have to monitor my Enphase micro inverters with a Enphase Envoy S Standard Communication Gateway and the EnecSys micro inverters are monitored via the original EnecSys gateway and a Rasberry Pie local to my network. EnecSys went out of business some years ago and finding a monitoring system was a problem although an online system has been set up by someone now for a fee.
I haven't had those symptoms but the last few days I have often found I couldn't get any information on the phone app, it was as if I wasn't logged in but it said the system was online. The app worked OK yesterday and today seems OK so hopefully normal service has resumed.My Solid Cloud keeps switching between the full detailed view with the proper chart, and a much simpler view with just a generation figure in an arc.
Anyone else getting this?
Sorry, only just seen this. No there is no other antenna apart from the WiFi dongle that connects to my internet. I'll look into this, I should have an antenna from an old router about somewhere that might do the job.Does your inverter have the little wifi antenna attached at the bottom? I could well imagine an installer leaving that off.
Mine seems to have quite impressive range going through two thick brick walls.
Not yet TechView is much help other than for viewing current use.
Not me, but lots of people on a FB group I'm on have seen this. Solis are updating the app to try and fix some of the figures, like the battery charge from grid showing as "generated power".My Solid Cloud keeps switching between the full detailed view with the proper chart, and a much simpler view with just a generation figure in an arc.
It seems like a pretty standard wifi antenna. Goes in the port behind where the dongle connects.Sorry, only just seen this. No there is no other antenna apart from the WiFi dongle that connects to my internet. I'll look into this, I should have an antenna from an old router about somewhere that might do the job.
It is standard, I have just put an old WiFi antenna on and it's giving me a much better range, thanks.It seems like a pretty standard wifi antenna. Goes in the port behind where the dongle connects.
I have remote control permission and can access the Control Inverter option as per above image, but cannot see any option to change battery charge time once I access control. Can you help?You can raise a ticket with Solis to ask for Remote Control from the App or Solis cloud website. You'll need a G3 datalogger and fairly recent firmware. I can change my battery charge times from my phone or laptop using that.
Perfect, thank you for the explanation, I obviously didn't look closely enough.From that screen, go into Work Mode -> Self-consumption -> Charge and Discharge
Also note, only the first charge current will count. If you set 3 different times, they'll all charge at the first rate.Perfect, thank you for the explanation, I obviously didn't look closely enough.
Update the Solis app, there was an update couple of days ago on app store.Not sure what Ginlong are playing at. The PV display has again disappeared from Solis Cloud.
If I made this many errors in my code, I'd have been fired long ago.
