@Truck driver
Suggestion for the array optimization, in regards to the 4x400W side panels array you got.
I'd suggest the following 2s2p configuration. With the assumption you will raise these panels above the ground(very important), given the shading you got I'd recommend installing the panels in landscape orientation and letting the panel's half-cut design(aka duo panels/two halves) do its thing.
In the drawing below in Landscape panel orientation, 2s2p configuration, your array will gain 4 columns of independent production, and the two panels on the right side(red) will not impact the production of the two panels on the left side(blue).
The blue panels are in series together, same goes for the red panels in the drawing. The two series, red and blue, are then connected in parallel.
