Hello all. I have a small system for an offgrid cabin. Currently consists of a Magnum inverter ( MS402PAE), two Midnite Kid charge controllers (30A), a 750 watt East facing array, a 750 watt West facing array, DIY built 24v 360AH LifePO4 battery bank (the replacement battery is my doing, everthing else was from the previous owner professional install). This system provides all I need for the late spring, summer and fall. Not so much during the Winter months (short days). I do have a generator to charge batteries, but i do not want it to run when I'm not there (no autostart). My main goal is keeping a celluar internet security system up and running 24/7. This system takes about 4Kw a day (24 hrs). The past few winters, I typically can stretch powering these loads for about 10-14 days before batteries and inverter shut off.
Trying to size up options to help bridge the gap in the winter months. I have purchased additional panels but trying to figure out the most economical way to add to my system. The existing Magnum system also has the load center.
Looking for suggestion. I'm contimplating adding an additional Kid charge controller and an additional 800 watt of panels, or a bigger different charge controller that could handle more amps and panels. I'm also curious about using micro inverters and (AC coupling) with the Magnum to help charge the battery.
Appreciate the input.
