Hi All I'm a newby regarding solar, I've installed a soyosource grid tie inverter 1Kw and with the limiter installed I can only get 50% output eg my power usage is 400w but the inverter will only give 200w, If I disably the ct by setting the inverter to battery constant mode it will give out the battery output power thats set in the inverter but when I set the inverter to batttery limit mode it will only give 50%, There is no mention in the instruction on which way the ct should be but I saw a youtube video which state the arrow should be pointing in from the grid to the fusebox( breaker box) but searching the web a few professionals say it should be pointing towards the grid. I've tried both ways and still gets the same result. looking at the leaflet that came with the inverter its showing the current detector point after the inverter but I cant connect the inverter before the fusebox and the ct in on the pigtail from the meter to the fusebox. beside isnt the ct suppose to detect that no power is been exported to the grid? if thats the case then how would the inverter knows if the ct is after it?
