Hey, as above my compression pack is almost at full travel on the springs due to some pack swelling (see post for details https://diysolarforum.com/threads/bulges-on-side-of-cells-during-top-balance.69878/#post-883917 )
It is 16s 280ah x2 rows of 8 cells with a six spring formation. The two swollen cells are nearest the springs, one on each row.
Reading lots of posts on swelling bulging, advice is not to release compression. However due to the springs being at full travel I don’t want to put the other cells at increased risk or over pressure when the pack is in use.
Since the swelling I have discharged the pack to 3.35v however the compression remains at full spring travel. I will post the spring compression rating if that helps.
Any advice would be appreciated. I was considering testing some loads and reducing some compression at a lower SOC
