Passing on some information from Borick.
- Regarding whether SRNE could fix the issue of setting 62 must be 50% or higher to avoid issue of ASP becoming stuck in bypass mode after fault shutdown, their answer was, "sorry, there is no way for the software to make changes at this time."
- Regarding whether there's a corresponding issue with setting 05 (is there a minimum required value for setting 05 to avoid the same stuck-in-bypass-mode issue?), their answer was, "the technician's recommendation is to set it as default. The problems created by the change cannot be predicted at this time."
- Borick provided a link to SRNE website (https://energy-for-all.notion.site/Solar-Storage-Inverter-624ddace6b81479fb5a3a2add895bf0d) that has additional configuration details not found in the manual.
