Capt Bill
Sailing Options
I am using 3 of those I purchased new at low cost via aliexpress ... for my 3 x 24v 280 Ah LiFePO4 sets . Specs say 0.07 amps at 24v for hold current ... for 1.7 watts Hold ... and brief 3.8 amp inrush to close contacts. IMO: Great way to go for BMS control of battery banks. I use SSR between my Chargery BMS8Ts and these relays to not over amp the BMS ... running 24 volt fuse at 5 amps (has not blow yet) ... to my 500 amp rated Contactors; ... to keep within my BMS trigger amp limits .. Also, I put a push button switch on electric wire to each relay; which give me nice easy option to turn any battery bank off and/or on, with an easy click of any 3 such switches. :+)You can use these contactors https://batteryhookup.com/collections/accessories/products/te-connectivity-ev200aaana-500a-0-900vdc
And don't let the thought of high hold current sway you, these have economizers attached only uses 1.7w to hold.
Added Note: .. When using SSR, ya got know about how they only work with the + to - current wired in the proper polarity direction.
